bougie iridium
Goto page: 1, 2, 3, 4, 5  >
K44rll
PostPosted: Sun 27 Apr - 16:40 (2008) Post subject: bougie iridium Reply with quote
Hi Jorge
Here is a link to www.suzukivanvan.co.uk message's http://uk.groups.yahoo.com/group/vanvanrv125/message/9
A cheap and easy to fit to upgrade your Vanvan Rv125...
O/E Spark Plug NGK CR8E
Iridium Spark Plug NGK CR8EIX
Spark Plug Gap 0.7 - 0.8mm
"NGK iridium plugs represent the ultimate evolution of spark plug
technology and performance. The iridium center electrode is both
stronger and harder than platinum. This allows NGK engineers to design
an ultra-fine (0.6mm)center electrode reducing the voltage requirement
for spark. This allows for a brighter, stronger spark from your
existing ignition system. The ground electrode has a tapered cut at the
firing end which reduces quenching for better flame core growth and
increased ignitability. The combination of fine wire center electrode
and tapered cut ground will increase performance, improve acceleration,
and fuel efficiency"
They are available on Ebay...
http://cgi.ebay.co.uk/NGK-IRIDIUM-IX-SPARK-PLUG-CR8E-IX-CR8EIX-4218_W0QQite…
Best regards
Karl
Gao
PostPosted: Sun 27 Apr - 18:00 (2008) Post subject: bougie iridium Reply with quote
salut jorge tu peux en trouver là  Arrow http://www.ixtem-moto.com/e_commerce/bougies/ngk/bougies-iridium-cr8eix-ngk…
j'en ai une et j'en suis très content
aver5
PostPosted: Sun 27 Apr - 19:53 (2008) Post subject: bougie iridium Reply with quote
J'en suis très content aussi
avec une bougie normale j'avais quelques "ratés" à plein régime  et maintenant c'est nickel ....
NOTE : VanVan k7 (injection)
Anto
PostPosted: Mon 28 Apr - 08:31 (2008) Post subject: bougie iridium Reply with quote
Honnetement je n'ai pas vu de différence avec la bougie d'origine mais théoriquement çà doit apporter un petit +.
Je l'ai commandé sur Ebay pour 12€
jha06
PostPosted: Mon 28 Apr - 09:59 (2008) Post subject: bougie iridium Reply with quote
j'ai moi aussi une iridium et par contre j'ai senti la différence, niveau reprise à l'accélération et à plein régime .....
VV
Gao
PostPosted: Wed 30 Apr - 22:49 (2008) Post subject: bougie iridium Reply with quote
Avec une bougie iridium pas de gain en puissance max,mais l'étincelle demande moins d'énergie et est plus puissante, d'où un gain en reprise. Le moteur se comporte mieux et à tendance à moins consommer. Mais l'avantage principal c'est la plus grande longévité et le fait que l'électrode se conserve très bien. Les perfs restent constantes pendant toutes la vie de la bougie (pas vrai pour une bougie basique)
Anto
PostPosted: Fri 2 May - 00:43 (2008) Post subject: bougie iridium Reply with quote
merci pour les précisions Gao.
VIDDA
PostPosted: Thu 15 May - 20:55 (2008) Post subject: bougie iridium Reply with quote
J'ai monté également une bougie irridium et c'est tip-top..j'avais des explosions dans mon pot NINJA à la décélèration et de rares petits ratés à haut régime (je précise que j'ai monté le kit up..) et depuis tous ces symptomes ont disparus !
Christo06
PostPosted: Fri 23 May - 13:46 (2008) Post subject: bougie iridium Reply with quote
Je confirme le lien de K44rll
http://cgi.ebay.fr/NGK-IRIDIUM-IX-SPARK-PLUG-CR8E-IX-CR8EIX-4218_W0QQitemZ2…
pour un achat immediat port compris : 10,43E
commandé et recu en 3 jours Okay
VV K8 Metallic Phantom Gray presque... d'origine
tikipakalolo
Masculin Scorpion (23oct-21nov) 蛇 Serpent
PostPosted: Fri 23 May - 19:55 (2008) Post subject: bougie iridium Reply with quote
moi aussi je lai commandé et recu en 4 jours
ptit lolo
aver5
PostPosted: Fri 23 May - 20:56 (2008) Post subject: bougie iridium Reply with quote
Je suis allé chez un accessoiriste moto et il y en avait  ....  (Dafy)
moose
PostPosted: Wed 20 Aug - 22:07 (2008) Post subject: bougie iridium Reply with quote
merci monsieur le concessionnaire,
une irridium et la perfection se perfectionne....
Van Van K6 Bleu d'origine, bougie Iridium, 8000km de bonheur en tongue...
http://rootspaysages.fr/
bibifricotin1
PostPosted: Wed 20 Aug - 22:24 (2008) Post subject: bougie iridium Reply with quote
J'ai lu sur certains forums qu'il fallait mettre de la graisse cuivrée sur les filetages de bougies avant remontage au couple préconisé, vous en pensez quoi ?
Yellow VanVan K6 - tout d'origine pour le moment
http://www.125miles.com
JCA
PostPosted: Thu 21 Aug - 11:18 (2008) Post subject: bougie iridium Reply with quote
J'en pense que je ne l'ai jamais fait. Comme je n'ai jamais fait gaffe au couple préconisé. Et que je n'ai jamais eu de problème.
pipe007
PostPosted: Thu 21 Aug - 23:22 (2008) Post subject: bougie iridium Reply with quote
Je viens d'en commander une .. sur le lien de Karl :
J'ai payé par CB, à suivre car je ne suis pas inscrit sur Paypal, je vous tiens au jus  de la livraison et des perfs
Nico
Ma petite entreprise ...
www.viewsurf.com
Webcams Beach, snow ...
daxteam corsica
PostPosted: Fri 22 Aug - 07:47 (2008) Post subject: bougie iridium Reply with quote
salut
un de mes fournisseurs est distibuteur NGK pour la thailande et la malaisie, si jamais je lui poserai la question sur les dispos de bougies iridium pour VV
le prix affiché sur ebay me semble quand même ridiculement bas, c'est le prix des séries platinum
par ailleurs je ne pense pas qu'il soit vraiment intéressant de faire rentrer une seule bougie d'angleterre, au niveau port c'est pas du tout rentable
c'est dommage parce que j'ai des CR8H-IX en stock, on les monte sur les dax préparés
pour ce qui est du grissage du filetage oui on peut le faire mais à l'arrivée peu de gens respectent vraiment les couples de serrage
à+
pipe007
PostPosted: Sun 24 Aug - 23:14 (2008) Post subject: bougie iridium Reply with quote
10 € avec le port au lieu de 17 € sans le port sur des sites Français, à suivre si c'est la bonne mais à priori,d'après les tonguistes sur le forum no PB, j te tiens au jus dès que la reçoit
Nico
www.viewsurf.com
pipe007
PostPosted: Sun 31 Aug - 21:27 (2008) Post subject: bougie iridium Reply with quote
Nickel, reçu en 4 jours, c'est bien une Iradium, je la monte demain  Okay 10,80 port compris
www.viewsurf.com
vanvan42
PostPosted: Tue 2 Sep - 10:07 (2008) Post subject: bougie iridium Reply with quote
VV76
PostPosted: Tue 2 Sep - 10:22 (2008) Post subject: bougie iridium Reply with quote
est ce que ce type de bougies se monte aussi bien sur l'ancien mod.(avec carbu) que sur le nouveau (injection) ?
merci bien d avance
Page 1 of 5
